Introduction
The Insignia 2-in-1 Handheld/Stick vacuum brush bristles can become worn down from continuous use. The bristles in the head might get damaged and need replacement, or the head might become obstructed with debris. Use this guide to help replace the brush head in the event of imperfect performance.
Pièces
Aucune pièce nécessaire.
Unscrew the single 12.0 mm Phillips #2 screw on the right side of the bottom of the vacuum head. Lift and pull up on the brush retention clip. Pull brush up and out to remove.
  • Unscrew the single 12.0 mm Phillips #2 screw on the right side of the bottom of the vacuum head.
  • Lift and pull up on the brush retention clip.
  • Pull brush up and out to remove.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Thibaut Pillot
Membre depuis le 15/02/2018
421 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S16-G3, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G3, Boczar Spring 2018
USFT-BOCZAR-S18S16G3
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 34
