Aller au contenu principal
Insignia Sport NS-4V17 Front Case Cover Replacement
Ce dont vous avez besoin
  1. Insignia Sport NS-4V17 Front Case Cover Replacement, Battery: étape 1, image 1 de 1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Front Case Cover Replacement: étape 2, image 1 de 2 Insignia Sport NS-4V17 Front Case Cover Replacement: étape 2, image 2 de 2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Front Case Cover Replacement: étape 3, image 1 de 1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Front Case Cover Replacement: étape 4, image 1 de 1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: étape 5, image 1 de 2 Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: étape 5, image 2 de 2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Front Case Cover Replacement: étape 6, image 1 de 1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Front Case Cover Replacement: étape 7, image 1 de 3 Insignia Sport NS-4V17 Front Case Cover Replacement: étape 7, image 2 de 3 Insignia Sport NS-4V17 Front Case Cover Replacement: étape 7, image 3 de 3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Front Case Cover Replacement: étape 8, image 1 de 1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
Wesley Ballar
Membre depuis le 04/18/13
88 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 12-36, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 347
