Introduction
Can't identify the source of your problem and suspect that the motherboard has something to do with it? This guide will show you how to remove the motherboard. Buckle down because this is the longest guide.
Pièces
Aucune pièce nécessaire.
Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
Ajouter un commentaire
Detach the back cover by carefully pulling up and out on the back plastic casing. Do not pull apart the red wire connecting the battery to the device.
  • Detach the back cover by carefully pulling up and out on the back plastic casing.
  • Do not pull apart the red wire connecting the battery to the device.
Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
  • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
  • Be careful to not tear the wires while opening the case.
Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
  • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
  • Do not disconnect wires from plastic connector.
Remove the four corner plastic covers on the back of the device using the plastic opening tool. Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
Using a Philips #00 screwdriver remove all four 4.5mm  corner screws located underneath the corner pads.
  • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
Carefully wedge the plastic opening tool into either long side of the device. Slowly move the plastic opening tool along the side of the device, separating the front and back case covers. Repeat these steps on the other side of the device.
  • Carefully wedge the plastic opening tool into either long side of the device.
  • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
  • Repeat these steps on the other side of the device.
Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
Remove the white plastic ring from around the scroll wheel with your fingers.
  • Remove the white plastic ring from around the scroll wheel with your fingers.
Hold the sides of the device firmly with one hand.
  • Hold the sides of the device firmly with one hand.
  • Push down on the black favorite switch with your other hand so that it is pushed into the case.
With the component pushed in, lift up the top of the motherboard from the case. Pull the motherboard from the top so that the audio jack and usb input are removed from the case socket.
  • With the component pushed in, lift up the top of the motherboard from the case.
  • Pull the motherboard from the top so that the audio jack and usb input are removed from the case socket.
Wesley Ballar
Membre depuis le 18/04/2013
88 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 12-36, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 221
