Aller au contenu principal
Instant Pot IP-DUO80 V2 LED Display Replacement
Ce dont vous avez besoin
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: étape 1, image 1 de 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: étape 1, image 2 de 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: étape 1, image 3 de 3
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: étape 2, image 1 de 3 Instant Pot IP-DUO80 V2 LED Display Replacement: étape 2, image 2 de 3 Instant Pot IP-DUO80 V2 LED Display Replacement: étape 2, image 3 de 3
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: étape 3, image 1 de 2 Instant Pot IP-DUO80 V2 LED Display Replacement: étape 3, image 2 de 2
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: étape 4, image 1 de 2 Instant Pot IP-DUO80 V2 LED Display Replacement: étape 4, image 2 de 2
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: étape 5, image 1 de 3 Instant Pot IP-DUO80 V2 LED Display Replacement: étape 5, image 2 de 3 Instant Pot IP-DUO80 V2 LED Display Replacement: étape 5, image 3 de 3
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: étape 6, image 1 de 1
    • Lift the silver outer shell off of the top black ring.
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: étape 7, image 1 de 3 Instant Pot IP-DUO80 V2 LED Display Replacement: étape 7, image 2 de 3 Instant Pot IP-DUO80 V2 LED Display Replacement: étape 7, image 3 de 3
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
6 autres ont terminé cette réparation.
Kayla Meacham
Membre depuis le 01/23/18
634 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S18-G2, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
4 membres
10 tutoriels rédigés
2 commentaires
Where can I get the replacement for the display?
Starfish Doodle - Réponse
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 38
Total : 6,729
