Introduction
This guide details the steps to take off the button pad of your Inter-tel IP 8660.
Pièces
Aucune pièce nécessaire.
Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
Ajouter un commentaire
Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out. 8 mm long 11 mm long
  • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
Lift up the back cover and set it aside.
  • Lift up the back cover and set it aside.
While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
Lift up the speaker.
  • Lift up the speaker.
Lift up the motherboard and set aside
  • Lift up the motherboard and set aside
Peel off all rubber button covers.
  • Peel off all rubber button covers.
Remove all plastic buttons.  (Note: Look at the initial picture for locations of each button set)
  • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
Équipe
Cal Poly, Team 11-24, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 663
