Introduction
This guide details the steps to take off the back cover of your Inter-tel IP 8660 handset.
Pièces
Aucune pièce nécessaire.
Disconnect the phone cord from the handset jack.
  • Disconnect the phone cord from the handset jack.
Ajouter un commentaire
Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head. Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset. Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
  • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
Équipe
Cal Poly, Team 11-24, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 555
