Pièces
Aucune pièce nécessaire.
Disconnect the phone cord from the handset jack.
  • Disconnect the phone cord from the handset jack.
Ajouter un commentaire
Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head. Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset. Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
  • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
While holding the handset front cover, grasp and twist the handset microphone and jack until they come free from the cover.
  • While holding the handset front cover, grasp and twist the handset microphone and jack until they come free from the cover.
Unscrew the 2 screws (8 mm long) that hold the receiver in place using a #1 Phillips screwdriver. Note: The screws come with washers. Note: The screws come with washers.
  • Unscrew the 2 screws (8 mm long) that hold the receiver in place using a #1 Phillips screwdriver.
  • Note: The screws come with washers.
Pull the red and green wires that connect the receiver to the microphone out from under the metal piece and black padding. Note: To insert the wires back underneath the black padding, pull the black padding back with your finger and use plastic opening tool to wedge the wires underneath the black padding.
  • Pull the red and green wires that connect the receiver to the microphone out from under the metal piece and black padding.
  • Note: To insert the wires back underneath the black padding, pull the black padding back with your finger and use plastic opening tool to wedge the wires underneath the black padding.
Équipe
Cal Poly, Team 11-24, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 861
