Aller au contenu principal
Interlink VP4550 Circuit Board Replacement
Ce dont vous avez besoin
  1. Interlink VP4550 Circuit Board Replacement, Case: étape 1, image 1 de 3 Interlink VP4550 Circuit Board Replacement, Case: étape 1, image 2 de 3 Interlink VP4550 Circuit Board Replacement, Case: étape 1, image 3 de 3
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Interlink VP4550 Circuit Board Replacement: étape 2, image 1 de 3 Interlink VP4550 Circuit Board Replacement: étape 2, image 2 de 3 Interlink VP4550 Circuit Board Replacement: étape 2, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Interlink VP4550 Circuit Board Replacement: étape 3, image 1 de 2 Interlink VP4550 Circuit Board Replacement: étape 3, image 2 de 2
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  4. Interlink VP4550 Circuit Board Replacement: étape 4, image 1 de 2 Interlink VP4550 Circuit Board Replacement: étape 4, image 2 de 2
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
  5. Interlink VP4550 Circuit Board Replacement, Circuit Board: étape 5, image 1 de 1
    • Avoid picking up the front of the device as you work so that loose parts will not shift.
    • Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
  6. Interlink VP4550 Circuit Board Replacement: étape 6, image 1 de 1
    • Slide the circuit board down from the tab located underneath the top of the back half
    • The laser is attached to the circuit board and will slide out of its own housing as you slide out the circuit board.
    • Use tweezers to gently remove it if it doesn't come out.
custer78
Membre depuis le 02/11/14
24 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-1, Buehl Spring 2014 Membre de l'équipe Ohio State, Team 1-1, Buehl Spring 2014
OSU-BUEHL-S14S1G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 248
