Pièces
Aucune pièce nécessaire.
Push in the plastic tab that can be seen through cracks in the front left corner using a spudger. Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
Ajouter un commentaire
Move down the same side and push in the plastic tab.
  • Move down the same side and push in the plastic tab.
Move to the front right side and once again push in the plastic tab.
  • Move to the front right side and once again push in the plastic tab.
  • There is not a fourth tab to push in after this one.
Grab the cover by the front side and pull upwards. You might encounter some resistance. Pull firmly, but don't yank it.
  • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
Tilt the front case down until the pegs detach from the bottom of the case. Lift up and outward.
  • Tilt the front case down until the pegs detach from the bottom of the case.
  • Lift up and outward.
  • The motherboard will be loose at this point.
Chris Rudolph
Membre depuis le 05/10/2010
46 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-53, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 7-53, Amido Fall 2010
CPSU-AMIDO-F10S7G53
4 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 2,937
