Aller au contenu principal
JBL Charge 4 Battery Replacement
Ce dont vous avez besoin
  1. JBL Charge 4 Battery Replacement, Speaker Grill: étape 1, image 1 de 1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Battery Replacement: étape 2, image 1 de 2 JBL Charge 4 Battery Replacement: étape 2, image 2 de 2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Battery Replacement: étape 3, image 1 de 1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Battery Replacement, Passive Bass Radiators: étape 4, image 1 de 2 JBL Charge 4 Battery Replacement, Passive Bass Radiators: étape 4, image 2 de 2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Battery Replacement: étape 5, image 1 de 2 JBL Charge 4 Battery Replacement: étape 5, image 2 de 2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Battery Replacement, Battery: étape 6, image 1 de 2 JBL Charge 4 Battery Replacement, Battery: étape 6, image 2 de 2
    • Remove the two 6mm Phillips #0 screws on the front side of the port bay cover.
  7. JBL Charge 4 Battery Replacement: étape 7, image 1 de 1
    • Gently slide the cover back and off the hooks.
    • Remove the port bay cover.
  8. JBL Charge 4 Battery Replacement: étape 8, image 1 de 3 JBL Charge 4 Battery Replacement: étape 8, image 2 de 3 JBL Charge 4 Battery Replacement: étape 8, image 3 de 3
    • Remove the two 6mm Phillips #0 screws.
    • Remove the four 8mm Phillips #0 screws.
  9. JBL Charge 4 Battery Replacement: étape 9, image 1 de 1
    • Lift up the battery cover.
  10. JBL Charge 4 Battery Replacement: étape 10, image 1 de 3 JBL Charge 4 Battery Replacement: étape 10, image 2 de 3 JBL Charge 4 Battery Replacement: étape 10, image 3 de 3
    • Remove the sticky tape to expose the white ribbon cable ZIF connector.
    • Flip up the black locking flap on the ZIF connector with the tip of a spudger or your fingernail to release the cable.
    • Remove the white ribbon cable from the battery cover and place the cover to the side.
  11. JBL Charge 4 Battery Replacement: étape 11, image 1 de 2 JBL Charge 4 Battery Replacement: étape 11, image 2 de 2
    • Remove the battery from the battery socket by gently pulling on it.
  12. JBL Charge 4 Battery Replacement: étape 12, image 1 de 3 JBL Charge 4 Battery Replacement: étape 12, image 2 de 3 JBL Charge 4 Battery Replacement: étape 12, image 3 de 3
    • Pull out the battery enough to expose the battery's wire connector.
    • Push down on the white tab and gently pull out the battery-device connector.
20 autres ont terminé cette réparation.
Sydney Seto
Membre depuis le 01/24/19
771 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S1-G1, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 membres
26 tutoriels rédigés
15 commentaires
Where do you buy a battery for a jbl Charge 4 ??
Matt hempel - Réponse
Probably just cut open the blue foil around the batteries and replace them by re-soldering the electronics onto new 18650 batteries.
correct me if I’m wrong here.
Brendon Reijnders -
If you know how to handle them and have experience with soldering them that's a yes if not those batteries are really dangerous if you don't know how to do it correctly.
Hart80 -
Where in the !&&* do i get a battery for a bluetooth speaker. What happened to the jbl charge 4 that it even goes out???
Shani Sanders - Réponse
My JBL charge 4 battery dead too. 9nly uses it for three months
osborne buhere - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 50
7 derniers jours : 255
30 derniers jours : 1,306
Total : 62,011
