Introduction
The motherboard is the most important part of the Jabra CRUISER2. It controls the device. This guide will tell you step-by-step how to remove the motherboard so you can replace it with a functioning one.
Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
  • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
  • Instructions iOpener
Ajouter un commentaire
Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
  • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
  • Pull the tool toward the back of the device to pry it open.
  • Repeat this process over all edges of the device.
Open up the device by pulling the front plate straight up from the back plate.
  • Open up the device by pulling the front plate straight up from the back plate.
Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket. Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
  • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
  • The names of the screwdriver heads are listed on the sides of each head.
Remove the motherboard from the device by lifting it up from the back plate.
  • Remove the motherboard from the device by lifting it up from the back plate.
Spartacus
Membre depuis le 17/10/2014
564 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team 8-13, Williams Fall 2014 Membre de l'équipe Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 549
