Introduction
A printed circuit board (PCB) mechanically supports and electronically connects electronic components using conductive tracks made of copper laminated onto a non-conductive plastic. The PCB reduces the amount of wires in a device and inherently makes any device more reliable. The step by step instructions will describe how to troubleshoot your PCB.
Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device. Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
Ajouter un commentaire
Remove the 3 AAA batteries from the device.
  • Remove the 3 AAA batteries from the device.
Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device. Pull apart the device once screws are loose, splitting the device in half.
  • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
  • Pull apart the device once screws are loose, splitting the device in half.
Keeping all wires connected to their attachments, place the front half of the device face down.
  • Keeping all wires connected to their attachments, place the front half of the device face down.
Inspect the printed circuit board for any breaks or cracks.
  • Inspect the printed circuit board for any breaks or cracks.
Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board. Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
Disconnect all wires from the PCB Remove the damaged PCB from the microphone
  • Disconnect all wires from the PCB
  • Remove the damaged PCB from the microphone
  • Place new PCB in the Justin Bieber Concert Microphone.
  • Connect all the wires to the new PCB using this soldering guide.
Mike Seyman
Membre depuis le 19/10/2014
425 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team 4-1, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 147
