Introduction
Use this guide to replace a worn drive belt in a Kenmore 110 Series Washing Machine.
Pièces
Aucune pièce nécessaire.
To avoid risk of electric shock, unplug the washing machine.
  • To avoid risk of electric shock, unplug the washing machine.
  • Lay the washing machine on its back.
Ajouter un commentaire
Using a 5/16" socket wrench, remove both screws from the belt cover. Remove the belt cover from the washer. Remove the belt cover from the washer.
  • Using a 5/16" socket wrench, remove both screws from the belt cover.
  • Remove the belt cover from the washer.
Using a 1/2" socket, remove the bolt securing the drive pulley. Remove the drive pulley and belt. When installing a new belt, wrap the belt around both the motor and drive pulleys before reinstalling the drive pulley.
  • Using a 1/2" socket, remove the bolt securing the drive pulley.
  • Remove the drive pulley and belt.
  • When installing a new belt, wrap the belt around both the motor and drive pulleys before reinstalling the drive pulley.
I have difficulty to remove the bolt suring the pulley. Is there any tricky to move the bolt?
John Wang - Réponse
need to remove shaft off pulley
Valery Ryz -
I have a very old Kenmore Washer. The belt is loose but not broken. How do I tighten?
teedle54 - Réponse
7 autre(s) ont terminé cette réparation.
Robert Trout
Membre depuis le 26/09/2012
742 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 15-43, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 membres
5 tutoriels rédigés
What would be reason that rinse cycle doesn't spin and it leaks
lauraleahenquinette - Réponse
Voir les statistiques:
Dernières 24 heures : 34
7 derniers jours : 270
30 derniers jours : 1,190
Total : 66,702
