Aller au contenu principal
Keurig K55 Lid Spring Replacement
Ce dont vous avez besoin
  1. Keurig K55 Lid Spring Replacement, Secondary Water Pump: étape 1, image 1 de 3 Keurig K55 Lid Spring Replacement, Secondary Water Pump: étape 1, image 2 de 3 Keurig K55 Lid Spring Replacement, Secondary Water Pump: étape 1, image 3 de 3
    • Lift the silver handle up.
    • Locate the screw and washer holding the handle in place on each side.
    • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
  2. Keurig K55 Lid Spring Replacement: étape 2, image 1 de 2 Keurig K55 Lid Spring Replacement: étape 2, image 2 de 2
    • Grab the handle and pull it upward and toward the rear of the device.
    • Lift the lid to the fully open position.
    • Remove the two 11mm Phillips screws located on the upper part of the device.
    • Be careful removing the screws; the needle here may be sharp.
  3. Keurig K55 Lid Spring Replacement: étape 3, image 1 de 3 Keurig K55 Lid Spring Replacement: étape 3, image 2 de 3 Keurig K55 Lid Spring Replacement: étape 3, image 3 de 3
    • Lower the lid to just before its closing position.
    • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
    • Gently pull the top cover upward and toward the front of the device to remove it.
  4. Keurig K55 Lid Spring Replacement: étape 4, image 1 de 3 Keurig K55 Lid Spring Replacement: étape 4, image 2 de 3 Keurig K55 Lid Spring Replacement: étape 4, image 3 de 3
    • Remove the two 11mm Phillips head screws securing the water pump.
    • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
    • Pull the other line from the water pump.
  5. Keurig K55 Lid Spring Replacement, Lid Spring: étape 5, image 1 de 2 Keurig K55 Lid Spring Replacement, Lid Spring: étape 5, image 2 de 2
    • Pull the spring off the front hook using two fingers.
    • The spring has a lot of tension, so grip the spring end tightly.
  6. Keurig K55 Lid Spring Replacement: étape 6, image 1 de 2 Keurig K55 Lid Spring Replacement: étape 6, image 2 de 2
    • Pull the spring off the other hook.
William O'Brien
Membre depuis le 01/23/18
500 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S1-G3, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 membres
5 tutoriels rédigés
2 commentaires
What is the small plastic/rubber angled water line part that the front part of the water pump valve is inserted into ?
Joe K - Réponse
Well i might have described it as a water pump in my above message, but from what I've read on here it is a check valve, so what is the rubber/plastic small angled water line part that the front of the check valve is inserted into !
Joe K - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 15
Total : 1,603
