Introduction
If your Keurig is unable to turn on, you may need to replace your power cable with this guide.
Pièces
Aucune pièce nécessaire.
Access the bottom of the Keurig by flipping it on its side. Access the bottom of the Keurig by flipping it on its side.
  • Access the bottom of the Keurig by flipping it on its side.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the five 13mm Phillips #0 screws securing the bottom case. Pull the silver cover off of the device. Pull the silver cover off of the device.
  • Remove the five 13mm Phillips #0 screws securing the bottom case.
  • Pull the silver cover off of the device.
To remove the power cable, highlighted in red, follow iFixit's guide on soldering. The ground cable, highlighted in orange, needs to be re-soldered to your new power cable. The ground cable, highlighted in orange, needs to be re-soldered to your new power cable.
  • To remove the power cable, highlighted in red, follow iFixit's guide on soldering.
  • The ground cable, highlighted in orange, needs to be re-soldered to your new power cable.
William O'Brien
Membre depuis le 23/01/2018
473 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S1-G3, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 23
Total : 94
