Introduction
Removal and replacement of the Keurig K55 secondary water pump.
Pièces
Aucune pièce nécessaire.
Lift the silver handle up. Locate the screw and washer holding the handle in place on each side. Remove both 13mm screws and washers using a Phillips #0 screwdriver.
  • Lift the silver handle up.
  • Locate the screw and washer holding the handle in place on each side.
  • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
Ajouter un commentaire
Grab the handle and pull it upward and toward the rear of the device. Lift the lid to the fully open position.
  • Grab the handle and pull it upward and toward the rear of the device.
  • Lift the lid to the fully open position.
  • Remove the two 11mm Phillips screws located on the upper part of the device.
  • Be careful removing the screws; the needle here may be sharp.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Lower the lid to just before its closing position. Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it. Gently pull the top cover upward and toward the front of the device to remove it.
  • Lower the lid to just before its closing position.
  • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
  • Gently pull the top cover upward and toward the front of the device to remove it.
Remove the two 11mm Phillips head screws securing the water pump. Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump. Pull the other line from the water pump.
  • Remove the two 11mm Phillips head screws securing the water pump.
  • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
  • Pull the other line from the water pump.
Mark Toujiline
Membre depuis le 30/09/2015
259 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S1-G3, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 78
Total : 272
