Aller au contenu principal
Keurig Mini B-31 K-cup Holder Replacement
Ce dont vous avez besoin
  1. Keurig Mini B-31 K-cup Holder Replacement, K-cup holder: étape 1, image 1 de 1
    • Lift up the handle of the Keurig Mini.
  2. Keurig Mini B-31 K-cup Holder Replacement: étape 2, image 1 de 2 Keurig Mini B-31 K-cup Holder Replacement: étape 2, image 2 de 2
    • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
    • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
  3. Keurig Mini B-31 K-cup Holder Replacement: étape 3, image 1 de 2 Keurig Mini B-31 K-cup Holder Replacement: étape 3, image 2 de 2
    • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
  4. Keurig Mini B-31 K-cup Holder Replacement: étape 4, image 1 de 1
    • Pull the K-cup holder straight out.
7 autres ont terminé cette réparation.
Andrew Adriance
Membre depuis le 01/14/14
1 914 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 17-1, Forte Winter 2014 Membre de l'équipe Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 membres
17 tutoriels rédigés
2 commentaires
Press up on the outlet of the holder to push it out. This is covered in the manufacturer’s user manual which comes with the unit when new.
jastpeel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 38
Total : 12,745
