Pièces
Aucune pièce nécessaire.
Turn the controller over to the backside and locate the battery cover screw.
  • Turn the controller over to the backside and locate the battery cover screw.
Ajouter un commentaire
The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
Once the screw is removed lift the battery cover up from the controller.
  • Once the screw is removed lift the battery cover up from the controller.
Remove the 2 AA batteries.
  • Remove the 2 AA batteries.
Remove both the 6.0mm Phillips #1 screws holding the D-pads in place.
  • Remove both the 6.0mm Phillips #1 screws holding the D-pads in place.
Insert wisdom here.
  • Insert wisdom here.
Remove the four  8.1 Phillips #1 screws (red:) and (orange:)
  • Remove the four 8.1 Phillips #1 screws (red:) and (orange:)
Lift the antenna holder away from the controller towards the top of the antenna.
  • Lift the antenna holder away from the controller towards the top of the antenna.
Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
  • Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
  • Separate both halves of the controller.
Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
  • Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
Remove the internal chip by pulling it away from the controller.
  • Remove the internal chip by pulling it away from the controller.
  • Remove both the positive(red wire) and negative(black wire) from the battery terminals.
  • Reverse the steps to put everything back together.
Where do you get the chip to replace?
Sandra Koll - Réponse
Rusbell Gonzalez
Membre depuis le 17/09/2014
219 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 104
