Introduction
To install a new keyboard into your Kindle 2 requires you to completely disassemble your device, but with this guide it should be fairly simple.
Ce dont vous avez besoin
Lay the Kindle face down on a soft cloth to protect its screen.
Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
Slide the gray plastic top piece away from the Kindle's metal casing.
Once the gray plastic top piece is detached from the metal back cover, remove it.
Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
Grab the bottom left corner of the keyboard.
Peel the keyboard off the device.
