May need to use something to pry it open such as a screwdriver. After you pop some of the little clips inside, you can use your fingers to remove it completely.
  • May need to use something to pry it open such as a screwdriver.
  • After you pop some of the little clips inside, you can use your fingers to remove it completely.
Ajouter un commentaire
The first photo shows two red circles over the screw that will need to be removed first. After lifting the tab as shown in the third photo you will need the part number located below  bar code. After lifting the tab as shown in the third photo you will need the part number located below  bar code.
  • The first photo shows two red circles over the screw that will need to be removed first.
  • After lifting the tab as shown in the third photo you will need the part number located below bar code.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Next you will need remove all of the little white sliders that hold tabs down. if your fingernails are any shorter than mine you may need to use something for assistance.
  • Next you will need remove all of the little white sliders that hold tabs down. if your fingernails are any shorter than mine you may need to use something for assistance.
Remove all of the wires that trace to the mother board. Two speaker wires Wire for battery
  • Remove all of the wires that trace to the mother board.
  • Two speaker wires
  • Wire for battery
Using your fillips screwdriver, remove the screws that have red circles around them. The screws that have blue circles around them should already be removed at this point but there are two remaining screws under that tab that also need to be removed. In addition, use your fingers to remove the tab that has a purple square around it.
  • Using your fillips screwdriver, remove the screws that have red circles around them.
  • The screws that have blue circles around them should already be removed at this point but there are two remaining screws under that tab that also need to be removed.
  • In addition, use your fingers to remove the tab that has a purple square around it.
Pull the motherboard out and order the part.
  • Pull the motherboard out and order the part.
Reed
Membre depuis le 06/03/2018
1 Réputation
1 tutoriel rédigé
Équipe
Vegas Room H9 Membre de l'équipe Vegas Room H9
Community
13 membres
15 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 12
