Aller au contenu principal
Kindle Paperwhite 1st Generation Motherboard Replacement
Ce dont vous avez besoin
  1. Kindle Paperwhite 1st Generation Motherboard Replacement, Case: étape 1, image 1 de 2 Kindle Paperwhite 1st Generation Motherboard Replacement, Case: étape 1, image 2 de 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
  2. Kindle Paperwhite 1st Generation Motherboard Replacement: étape 2, image 1 de 3 Kindle Paperwhite 1st Generation Motherboard Replacement: étape 2, image 2 de 3 Kindle Paperwhite 1st Generation Motherboard Replacement: étape 2, image 3 de 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
  3. Kindle Paperwhite 1st Generation Motherboard Replacement: étape 3, image 1 de 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
  4. Kindle Paperwhite 1st Generation Motherboard Replacement, Battery: étape 4, image 1 de 2 Kindle Paperwhite 1st Generation Motherboard Replacement, Battery: étape 4, image 2 de 2
    • Turn over the midframe to locate the battery.
    • Remove the three Phillips 3.0 mm screws securing the battery to the midframe.
  5. Kindle Paperwhite 1st Generation Motherboard Replacement: étape 5, image 1 de 1
    • Gently lift the battery from the bottom, and slide it out of the midframe.
  6. Kindle Paperwhite 1st Generation Motherboard Replacement, Motherboard: étape 6, image 1 de 3 Kindle Paperwhite 1st Generation Motherboard Replacement, Motherboard: étape 6, image 2 de 3 Kindle Paperwhite 1st Generation Motherboard Replacement, Motherboard: étape 6, image 3 de 3
    • With the case and battery removed from the midframe, begin removing all cables attached to the motherboard.
    • Place the device so the midframe's backside faces up. Start with the cable on the bottom left corner.
    • Use a spudger to lift up the white locking cable tensioner and slide the flex cable out.
    • Proceed counterclockwise to the next cable and repeat. Small flex cable on the bottom won't need cable tensioner lifted, just carefully pull out.
  7. Kindle Paperwhite 1st Generation Motherboard Replacement: étape 7, image 1 de 2 Kindle Paperwhite 1st Generation Motherboard Replacement: étape 7, image 2 de 2
    • Remove the white flex cable by gently lifting the yellow plastic connector.
  8. Kindle Paperwhite 1st Generation Motherboard Replacement: étape 8, image 1 de 3 Kindle Paperwhite 1st Generation Motherboard Replacement: étape 8, image 2 de 3 Kindle Paperwhite 1st Generation Motherboard Replacement: étape 8, image 3 de 3
    • Remove the yellow anti-static tape from the display ribbon cable connector.
    • Use a spudger to lift up and disconnect the cable tensioner.
  9. Kindle Paperwhite 1st Generation Motherboard Replacement: étape 9, image 1 de 2 Kindle Paperwhite 1st Generation Motherboard Replacement: étape 9, image 2 de 2
    • Use a Philips screwdriver to remove the seven 3.0 mm Phillips screws securing the motherboard:
    • Three silver screws with silver washers
    • Two silver screws with no washers
    • One black screw with a golden washer
    • One black screw with a square washer
  10. Kindle Paperwhite 1st Generation Motherboard Replacement: étape 10, image 1 de 1
    • Remove the motherboard.
6 autres ont terminé cette réparation.
Isabelle Burgess
Membre depuis le 01/23/13
1 621 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-33, Amido Winter 2013 Membre de l'équipe Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 membres
17 tutoriels rédigés
2 commentaires
Not sure if this is an error, but on the 3G paperwhite, we needed to use a #0 Phillips, not a #2. Great guide otherwise!
Caleb Begly - Réponse
Please suggest what type of controller is used and the model and flash memory in the Kindle Paperwhite 1st Generation?
ven 1949, div 0004
Elecrash - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 78
Total : 20,391
