Introduction
Removing the bowl screw cap is easy and doesn't take long. If the bowl doesn't stay in properly you might want to replace this part.
Pièces
Aucune pièce nécessaire.
Using a #2 Phillips screwdriver, remove the three 13mm screws holding the bowl screw cap on by rotating them counterclockwise. Using a #2 Phillips screwdriver, remove the three 13mm screws holding the bowl screw cap on by rotating them counterclockwise.
  • Using a #2 Phillips screwdriver, remove the three 13mm screws holding the bowl screw cap on by rotating them counterclockwise.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the bowl screw cap by grabbing the side and lifting up on it.
  • Remove the bowl screw cap by grabbing the side and lifting up on it.
Luke Leonard
Membre depuis le 24/01/2018
349 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S2-G5, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 33
