Aller au contenu principal
KitchenAid KSM150PSER Circuit Board Replacement
Ce dont vous avez besoin
  1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: étape 1, image 1 de 2 KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: étape 1, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling it back and up.
    • Ensure that the mixer is disconnected from any electrical source prior to removing the back cover.
  2. KitchenAid KSM150PSER Circuit Board Replacement: étape 2, image 1 de 2 KitchenAid KSM150PSER Circuit Board Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the 9.5mm screw above the circuit board by rotating it counterclockwise.
    • If you can't see the screw, try pulling the seal down past the wires to make the screw more accessible.
  3. KitchenAid KSM150PSER Circuit Board Replacement: étape 3, image 1 de 2 KitchenAid KSM150PSER Circuit Board Replacement: étape 3, image 2 de 2
    • Using pliers or tweezers, remove the connectors of the four wires attached to the circuit board.
  4. KitchenAid KSM150PSER Circuit Board Replacement: étape 4, image 1 de 1
    • Grab the wires and tilt the edge of the board up to lift the circuit board up and out.
4 autres ont terminé cette réparation.
Luke Leonard
Membre depuis le 01/24/18
562 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S2-G5, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 39
Total : 5,199
