Aller au contenu principal
KitchenAid KSM150PSER Power Cord Replacement
Ce dont vous avez besoin
  1. KitchenAid KSM150PSER Power Cord Replacement, Power Cord: étape 1, image 1 de 2 KitchenAid KSM150PSER Power Cord Replacement, Power Cord: étape 1, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Power Cord Replacement: étape 2, image 1 de 2 KitchenAid KSM150PSER Power Cord Replacement: étape 2, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Power Cord Replacement: étape 3, image 1 de 2 KitchenAid KSM150PSER Power Cord Replacement: étape 3, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the 12mm screw holding the grounding wire in place by rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the white and black wires.
  4. KitchenAid KSM150PSER Power Cord Replacement: étape 4, image 1 de 2 KitchenAid KSM150PSER Power Cord Replacement: étape 4, image 2 de 2
    • Using a screwdriver, pull the cord string relief out of the mixer by putting it behind the cord and pulling away from the mixer until it is free.
    • Remove the cord from the mixer body.
Max Prohorov
Membre depuis le 01/24/18
109 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S2-G5, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 53
Total : 3,958
