Pièces
Aucune pièce nécessaire.
Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
  • Place thumb firmly on battery cover.
  • Slide thumb right, the cover should follow and pop up.
Ajouter un commentaire
Place thumb on orange tab and pull back towards screen. The battery should pop up.
  • Place thumb on orange tab and pull back towards screen.
  • The battery should pop up.
  • Gently lift battery out.
Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
  • Remove screws from along outer edge of casing.
  • There are 6 screws in total.
  • Righty tighty, lefty loosey!
Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
  • Gently lift off front and back casing.
Remove screws along side. Gently peel off side casing. Gently peel off side casing.
  • Remove screws along side.
  • Gently peel off side casing.
Gently lift up the LCD screen after removing back casing. Find the point where the orange ribbon cable attaches to mother board.
  • Gently lift up the LCD screen after removing back casing.
  • Find the point where the orange ribbon cable attaches to mother board.
Use plastic opening tool to gently lift up on the ribbon cable fastener. Note: It does not take much pressure to release fastener.
  • Use plastic opening tool to gently lift up on the ribbon cable fastener.
  • Note: It does not take much pressure to release fastener.
Lift LCD Screen off of device.
  • Lift LCD Screen off of device.
Brian
Membre depuis le 13/03/2014
252 Réputation
2 tutoriels rédigés
Équipe
New Mexico State, Team 1-2, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-2, Easley Spring 2014
NMSU-EASLEY-S14S1G2
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 96
