Introduction
Front and Back view of camera. Use a Philips Head screw driver to unscrew the sides of the camera. There are six screws total. Front and Back view of camera. Use a Philips Head screw driver to unscrew the sides of the camera. There are six screws total.
  • Front and Back view of camera. Use a Philips Head screw driver to unscrew the sides of the camera. There are six screws total.
Ajouter un commentaire
Use a Philips Head screw driver to unscrew the sides of the camera. There are two screws on each side except for the top of the camera. Carefully remove face plate of camera. Place alongside near screws. Use a Philips Head screw driver to unscrew the sides of the camera. There are two screws on each side except for the top of the camera. Carefully remove face plate of camera. Place alongside near screws.
  • Use a Philips Head screw driver to unscrew the sides of the camera. There are two screws on each side except for the top of the camera. Carefully remove face plate of camera. Place alongside near screws.
To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens. To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens. To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens.
  • To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens.
Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed. Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed. Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed.
  • Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed.
Remove additional screws near lens. Remove additional screws near lens.
  • Remove additional screws near lens.
This is what the camera should look like with all screws are removed. Flip camera over to carefully remove the screen cover. This is what the camera should look like with all screws are removed. Flip camera over to carefully remove the screen cover.
  • This is what the camera should look like with all screws are removed. Flip camera over to carefully remove the screen cover.
Remove buttons from back case of screen cover. Replace with new set of buttons. Remove buttons from back case of screen cover. Replace with new set of buttons.
  • Remove buttons from back case of screen cover. Replace with new set of buttons.
Follow the steps in reverse order to reassemble the camera. Now you can take beautiful pictures again!
  • Follow the steps in reverse order to reassemble the camera. Now you can take beautiful pictures again!
Once you purchase these parts, follow the given instructions. To reassemble your device, follow these instructions in reverse order.
3 autre(s) ont terminé cette réparation.
Elizabeth
Membre depuis le 28/01/2015
279 Réputation
2 tutoriels rédigés
Équipe
Penn State, Team 1-2, Kaschak Winter 2015 Membre de l'équipe Penn State, Team 1-2, Kaschak Winter 2015
PSU-KASCHAK-W15S1G2
1 membre
2 tutoriels rédigés
como cambio la tapa de la bateria y pin de carga
Dario - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 255
