Introduction
Back Cover Teardown guide must be used first to get inside the camera. Later, soldering guides will be used.
Pièces
Aucune pièce nécessaire.
Remove the two 6.2mm Phillips screws on both sides of camera's back cover. Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
Ajouter un commentaire
Turn camera so the bottom is facing up and the front is facing away.
  • Turn camera so the bottom is facing up and the front is facing away.
  • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
  • Back cover is now unscrewed an can be removed.
Have the back of the camera facing up.
  • Have the back of the camera facing up.
  • Unscrew the 6.2mm Phillips screw next to the viewfinder.
  • The back cover is now unscrewed. Lift up and pull the cover off evenly.
The capacitor is located at the bottom center of the camera.
  • The capacitor is located at the bottom center of the camera.
Desolder the two connections at the top of the flash capacitor.
Michelle
Membre depuis le 04/04/2011
86 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-28, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,722
