Aller au contenu principal
Kodak S100 EF Flash Replacement
Ce dont vous avez besoin
  1. Kodak S100 EF Flash Replacement, Front Cover: étape 1, image 1 de 1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Flash Replacement: étape 2, image 1 de 1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Flash Replacement: étape 3, image 1 de 1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
  4. Kodak S100 EF Flash Replacement, Flash: étape 4, image 1 de 1
Nick
Membre depuis le 04/26/11
4 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 25-28, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 20
Total : 2,619
