Introduction
This will guide through the process of rolling up to remove the film as well as replacing it with a new roll. The Kodak S100 EF uses 35mm film.
Outils
Aucun outil requis.
Pièces
Lift up the lever from the center of the film roller.
  • Lift up the lever from the center of the film roller.
  • Turn it clockwise to roll up the film until you feel the roller release, indicating all the film has been rolled up.
Ajouter un commentaire
On the far left side on the back of the camera there is a switch that says "open."
  • On the far left side on the back of the camera there is a switch that says "open."
  • Slide the button up to the top where it says "open."
  • This should pop open the door, revealing the rolled up film inside.
To take out the old film and insert the new, you must lift up on the film roller.
  • To take out the old film and insert the new, you must lift up on the film roller.
  • Pull up on the lever to pop the roller up which will release the film.
  • After old roll is removed, slide in the new roll and push the roller back down to secure the film.
To prepare the film for use, grab the tail of the film and pull it out slightly.
  • To prepare the film for use, grab the tail of the film and pull it out slightly.
  • Drag it out to the rotating column on the right side.
  • At the base of the column there are hooks to attach to the holes at the bottom of the film.
  • Slip one of the hooks into the first hole of your film to attach.
After film is secured, close the camera door.
  • After film is secured, close the camera door.
  • Make sure the lever is put back in place on the film roller.
  • Use the scroll wheel to advance the film until it is ready to take pictures.
Once the film is in place-to reassemble the camera-close the camera door and make sure the scroll wheel is pushed back down.
Michelle
Membre depuis le 04/04/2011
86 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-28, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 39
Total : 3,638
