Make sure to open the back cover easily using the plastic opening tool.
  • Make sure to open the back cover easily using the plastic opening tool.
Ajouter un commentaire
Remove back cover by prying away from the device. The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides. Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  • Remove back cover by prying away from the device.
  • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
  • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
  • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
Gently remove the plastic cover that is covering the camera.
  • Gently remove the plastic cover that is covering the camera.
Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
Use the soldering tool to detach the speaker wires.
  • Use the soldering tool to detach the speaker wires.
  • For more information on how to solder the wires Click here
Press the speaker in the manner shown so that it comes out of its slot.
  • Press the speaker in the manner shown so that it comes out of its slot.
  • Be sure not to apply too much force or you can break the back cover.
Use the Tweezers to remove the speaker from its place.
  • Use the Tweezers to remove the speaker from its place.
  • Remove the speaker gently.
Moin Khan
Membre depuis le 21/01/2015
222 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 6-5, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 126
