Aller au contenu principal
LCD LG 37LF65 Capacitor replacement
Ce dont vous avez besoin
  1. LCD LG 37LF65 Capacitor replacement, Open the case: étape 1, image 1 de 1
    • Power off and unplug your device before starting this repair.
    • Open the case carefully while loosing the marked srews.
  2. LCD LG 37LF65 Capacitor replacement, Replace the capacitors: étape 2, image 1 de 1
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  3. LCD LG 37LF65 Capacitor replacement, Testing capacitors: étape 3, image 1 de 1
    • If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
9 autres ont terminé cette réparation.
eugl18
Membre depuis le 01/18/13
561 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 41
Total : 13,346
