Introduction
To isolate the LCD screen, one needs to be gentle with separating parts and removing screws from the camera.
Pièces
Aucune pièce nécessaire.
Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
  • Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
Ajouter un commentaire
Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together. To get to the second screw, rotate the screen.
  • Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together.
  • To get to the second screw, rotate the screen.
Gently peel off the front and back cover of the screen. Peel back the plastic cover. Peel back the plastic cover.
  • Gently peel off the front and back cover of the screen.
  • Peel back the plastic cover.
Gently pull off the screen from the base.
  • Gently pull off the screen from the base.
  • A small metal piece between the screen cover and the screen may fall out during repair. Remember to replace it with the rounded corners facing away from the screen during reassembly.
  • This takes a little force.
Unplug the wires that are attaching the screen to the circuit board.
  • Unplug the wires that are attaching the screen to the circuit board.
2 autre(s) ont terminé cette réparation.
konrad
Membre depuis le 11/01/2011
214 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-31, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 membres
6 tutoriels rédigés
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 3,276
