Introduction
This guide will help you with the process of replacing the Wi-Fi PCI Card in your device.
Pièces
Aucune pièce nécessaire.
Unscrew the two screws using a Phillips #0 screwdriver.
  • Unscrew the two screws using a Phillips #0 screwdriver.
Ajouter un commentaire
Use a spudger to lift the back cover and remove it from the device.
  • Use a spudger to lift the back cover and remove it from the device.
Unplug the two wires that are on the Wi-Fi PCI card (white & black).
  • Unplug the two wires that are on the Wi-Fi PCI card (white & black).
Unscrew the single screw in front of the Wi-Fi PCI card using the Phillips #0 screwdriver.
  • Unscrew the single screw in front of the Wi-Fi PCI card using the Phillips #0 screwdriver.
Remove the Wi-Fi PCI card from the device.
  • Remove the Wi-Fi PCI card from the device.
abdualmjeed Alabdurazzaq
Membre depuis le 15/01/2018
471 Réputation
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 8
Total : 21
