Aller au contenu principal
LG 1010 Front Cover Replacement
Ce dont vous avez besoin
  1. LG 1010 Front Cover Replacement, Front  Cover: étape 1, image 1 de 2 LG 1010 Front Cover Replacement, Front  Cover: étape 1, image 2 de 2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  2. LG 1010 Front Cover Replacement: étape 2, image 1 de 1
    • Remove two screws using a Torx T6 screwdriver.
  3. LG 1010 Front Cover Replacement: étape 3, image 1 de 2 LG 1010 Front Cover Replacement: étape 3, image 2 de 2
    • Pry off the screen front cover with a small flathead screwdriver.
  4. LG 1010 Front Cover Replacement: étape 4, image 1 de 1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  5. LG 1010 Front Cover Replacement: étape 5, image 1 de 1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  6. LG 1010 Front Cover Replacement: étape 6, image 1 de 1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
Nicholas Schmidt
Membre depuis le 10/09/10
97 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 3-25, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 1,001
