Introduction
This replacement guide will show you how to safely and properly remove the screen on your LG G Pad X 8.3.
Remove the cover of the SD card. Find it on the right side of the back of the tablet.
  • Remove the cover of the SD card. Find it on the right side of the back of the tablet.
  • Press the SD card in to make it pop out.
Ajouter un commentaire
Slide the stylus out from the bottom left corner of the back panel.
  • Slide the stylus out from the bottom left corner of the back panel.
Start at a corner and pry the screen up with a plastic opening tool.
  • Start at a corner and pry the screen up with a plastic opening tool.
  • You can also use a plastic spudger for this task, but do not use metal tools. They can be dangerous to you and the device.
  • Slide the tool in the seam at the edge of the screen.
  • Wedge additional plastic opening tools in the seam to help lift the screen.
  • Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
  • If your screen is cracked, work slowly to avoid flinging glass shards when prying.
With a  Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery. With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector. Use a magnetic mat to keep track of these tiny screws for later reassembly.
  • With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
  • With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
  • Use a magnetic mat to keep track of these tiny screws for later reassembly.
Lift the battery ribbon connector with your finger.
  • Lift the battery ribbon connector with your finger.
Lift the battery with your fingers and remove it from the device.
  • Lift the battery with your fingers and remove it from the device.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
  • With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
  • Use the magnetic mat to keep track of the tiny screw(s).
Lift and remove the speaker with your finger.
  • Lift and remove the speaker with your finger.
With the Phillips #000  screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard. With the Phillips #000  screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
  • With the Phillips #000 screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
Use a plastic opening tool to lift up the ribbon connector at the bottom of the motherboard. Only lift up the end of the ribbon connector that is attached to the motherboard. The end at the base of the tablet should stay attached.
  • Use a plastic opening tool to lift up the ribbon connector at the bottom of the motherboard.
  • Only lift up the end of the ribbon connector that is attached to the motherboard. The end at the base of the tablet should stay attached.
Lift and release the remaining ribbon connectors in the upper left corner of the motherboard with a plastic opening tool. Avoid bending the tips of the ribbon connectors to prevent damage. Avoid bending the tips of the ribbon connectors to prevent damage.
  • Lift and release the remaining ribbon connectors in the upper left corner of the motherboard with a plastic opening tool.
  • Avoid bending the tips of the ribbon connectors to prevent damage.
With your fingers, lift up the motherboard from the upper right corner. Carefully remove the fragile motherboard from the device.
  • With your fingers, lift up the motherboard from the upper right corner.
  • Carefully remove the fragile motherboard from the device.
Insert the plastic opening tool under the ribbon connector that is holding the rear-facing camera down and lift it up.
  • Insert the plastic opening tool under the ribbon connector that is holding the rear-facing camera down and lift it up.
After prying ribbon connector, the rear-facing camera should be ready for removal. Gently lift the rear-facing camera with your fingers and remove.
  • After prying ribbon connector, the rear-facing camera should be ready for removal.
  • Gently lift the rear-facing camera with your fingers and remove.
Cover the screen with duct tape.
  • Cover the screen with duct tape.
  • This step is optional. Recommended for cracked screens.
  • The tablet screen has a lot of adhesive, which makes the removal longer. Be patient.
Insert the plastic opening tool on one of the corners of the device.
  • Insert the plastic opening tool on one of the corners of the device.
  • Slowly go around the edge of the tablet with the plastic opening tool and pry upward.
  • Use multiple plastic opening tools underneath areas that have been pried open. This will prevent the screen from sticking back to the adhesive and it will make removal easier.
  • Gift, Debit or Credit cards work effectively to keep screen pried opening.
Lift upward and slowly remove screen. Lift upward and slowly remove screen.
  • Lift upward and slowly remove screen.
Michael H
Membre depuis le 09/04/2018
423 Réputation
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 20
Total : 34
