Introduction
This guide will teach you how to replace the speaker in your LG G Vista. The speaker is easily replaceable, and you will have a brand new speaker in no time as long as you have a Phillips #000 screwdriver.
Pièces
Aucune pièce nécessaire.
Use a Phillips #000 screwdriver to remove five 3.0 mm screws.
  • Use a Phillips #000 screwdriver to remove five 3.0 mm screws.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a plastic opening tool, or your fingernail, to lift up the bottom hard shell cover. Remove the hard shell from the device. This hard shell covering that you are removing contains the speaker.
  • Use a plastic opening tool, or your fingernail, to lift up the bottom hard shell cover.
  • Remove the hard shell from the device.
  • This hard shell covering that you are removing contains the speaker.
To insert your new loudspeaker, simply take the piece and snap firmly into the place of the previous loudspeaker.
  • To insert your new loudspeaker, simply take the piece and snap firmly into the place of the previous loudspeaker.
Key Baker
Membre depuis le 18/01/2018
676 Réputation
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 55
