Introduction
If moisture has entered your LG G Watch, you will need to replace the gasket, and possibly the battery and the motherboard.
Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
  • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
  • Be prepared to apply some pressure with your fingers to perform the following action.
  • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
  • Grasp the exposed shoulder with the tweezers to perform the next step.
Is there a reason you are removing the straps before the back of the watch? They don't block the back from coming off or really get in the way much.
Andy Wickham - Réponse
its in the way, obviously it need to take them off, lol.
silentg4real -
Where can I get this battery?
Josh Wheat - Réponse
where can i buy a new replacement rear case? please let me know!
silentg4real - Réponse
I'd like to know as well and don't care if it's a knock off either
Joseph Wellman -
This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband. Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
  • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
  • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
  • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
  • Repeat steps 1 and 2 for the other wristband.
Ajouter un commentaire
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Slide the opening pick between the rear case and the rest of the device to separate the two halves. Gently pull the two halves apart.
  • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
  • Gently pull the two halves apart.
Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
Deja Miller
Membre depuis le 14/10/2014
438 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 2-5, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 469
