Aller au contenu principal
LG G5 Charging Port Replacement
Ce dont vous avez besoin
  1. LG G5 Charging Port Replacement, Battery: étape 1, image 1 de 3 LG G5 Charging Port Replacement, Battery: étape 1, image 2 de 3 LG G5 Charging Port Replacement, Battery: étape 1, image 3 de 3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Charging Port Replacement: étape 2, image 1 de 2 LG G5 Charging Port Replacement: étape 2, image 2 de 2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
  3. LG G5 Charging Port Replacement, Charging Port: étape 3, image 1 de 2 LG G5 Charging Port Replacement, Charging Port: étape 3, image 2 de 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Charging Port Replacement: étape 4, image 1 de 2 LG G5 Charging Port Replacement: étape 4, image 2 de 2
    • Insert the plastic opening tool into the bottom seam
    • Pry the plastic from the base only a slight amount.
  5. LG G5 Charging Port Replacement: étape 5, image 1 de 2 LG G5 Charging Port Replacement: étape 5, image 2 de 2
    • Remove the one 5.5mm Phillips #000 screw.
  6. LG G5 Charging Port Replacement: étape 6, image 1 de 3 LG G5 Charging Port Replacement: étape 6, image 2 de 3 LG G5 Charging Port Replacement: étape 6, image 3 de 3
    • Insert the plastic opening tool into the seam between the two plastic layers.
    • Pry the plastic from the body.
  7. LG G5 Charging Port Replacement: étape 7, image 1 de 2 LG G5 Charging Port Replacement: étape 7, image 2 de 2
    • Insert the plastic opening tool into the seam under the metal charging port.
    • Pry the metal charging port from the body.
23 autres ont terminé cette réparation.
Joshua Zalmanowitz
Membre depuis le 09/27/16
1 811 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-2, Forte Fall 2016 Membre de l'équipe Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 membres
15 tutoriels rédigés
13 commentaires
I would love steps to show not only pulling out the usb port, but also putting the new one in and re-assembly. Also maybe tips about things to avoid doing -- easy slip ups people make when doing it. Why replace just the usb port instead of the whole board assembly or instead of the entire bottom module? Thanks! Great pics
jessicacollins267 - Réponse
Anyone know how to bypass the "insert a supported module" error that comes up after changing the charging port?
Rene - Réponse
Do you solve the problem? Can you help me, please?
Budai Daniel -
I need to do this repair on my phone, but Rene's comment worries me. Does this error message come up often? Can it be fixed?
Brad - Réponse
Hello. I have the same problem like Rene . I changed the usb port and when I try to power on my smartphone it shows me the picture that said “insert a supported module” like what Rene said earlier. Please, I need help.
Budai Daniel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 34
Total : 23,834
