Introduction
If the speaker is blown or no sound is coming out this will show you how to replace a broken speaker.
Pièces
Aucune pièce nécessaire.
Use a plastic opening tool to remove the back cover.
  • Use a plastic opening tool to remove the back cover.
Ajouter un commentaire
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
Use a plastic opening tool to remove the back trim by working around all of the edges. Use a plastic opening tool to remove the back trim by working around all of the edges.
  • Use a plastic opening tool to remove the back trim by working around all of the edges.
Remove the volume buttons from the side. Remove the volume buttons from the side.
  • Remove the volume buttons from the side.
Use a plastic opening tool to lift the speaker off by prying under the silver square as shown. Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
  • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
Daniela Allbright
Membre depuis le 08/10/2014
554 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 14-1, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 144
