Introduction
Make sure your phone is turned off before beginning any dissection of your device.
Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage. Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
Ajouter un commentaire
The battery is the large black rectangle towards the bottom half of the phone. There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out. There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
  • The battery is the large black rectangle towards the bottom half of the phone.
  • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
Remove 9 screws from the phone. The locations of these screws are circled in the picture. 5.5mm length PH00 screws
  • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
  • 5.5mm length PH00 screws
  • 4mm length PH00 screws
Gently pull down on the bottom cover to remove it. Gently pull down on the bottom cover to remove it.
  • Gently pull down on the bottom cover to remove it.
Using a plastic opening tool, gently pry around the perimeter of the device. The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them. The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
  • Using a plastic opening tool, gently pry around the perimeter of the device.
  • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
  • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
I think they want you to refer to the blue tool as the "plastic opening tool."
Dan Brown - Réponse
Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board. Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
  • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
  • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
  • Evenly heat the device in short intervals for about one minute.
  • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
You could also use the iOpener tool for this step. What is that the adhesive is holding in place?
Dan Brown - Réponse
Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well. If the board is too difficult to separate than more heating may be required. If the board is too difficult to separate than more heating may be required.
  • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
  • If the board is too difficult to separate than more heating may be required.
Heat the camera assembly in 20-30 seconds intervals with a heat gun set on low, or a hair drying set on high.
  • Heat the camera assembly in 20-30 seconds intervals with a heat gun set on low, or a hair drying set on high.
  • Although the motherboard assembly has been removed in the picture, it is not necessary to remove it for camera removal.
Using tweezers or a pry tool, gently wiggle and lift the camera assembly away from the body of the phone. Although the motherboard has been removed in the pictures, it is not necessary to remove it before removing the camera.
  • Using tweezers or a pry tool, gently wiggle and lift the camera assembly away from the body of the phone.
  • Although the motherboard has been removed in the pictures, it is not necessary to remove it before removing the camera.
Dale Pearson
Membre depuis le 22/09/2014
775 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 10-6, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 201
