Introduction
This guide will take you through the process of replacing the power button in an LG Optimus F60. This task should take about 2-4 minutes to complete.
Pièces
Aucune pièce nécessaire.
Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port. Pry or lift up on the indent with the opening tool. Remove the back panel.
  • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
  • Pry or lift up on the indent with the opening tool.
  • Remove the back panel.
Ajouter un commentaire
Place the small plastic opening tool or your finger at the indentation at the base of the battery. Pry upwards or lift with your finger and remove battery. Pry upwards or lift with your finger and remove battery.
  • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
  • Pry upwards or lift with your finger and remove battery.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the eight 4 mm screws on the inner panel using the phillips #000 Screwdriver Remove the eight 4 mm screws on the inner panel using the phillips #000 Screwdriver
  • Remove the eight 4 mm screws on the inner panel using the phillips #000 Screwdriver
Remove inner panel using plastic opening tool. Apply force upwards while wiggling the tool further in. Remove bottom of inner panel.
  • Remove inner panel using plastic opening tool.
  • Apply force upwards while wiggling the tool further in.
  • Remove bottom of inner panel.
Use plastic opening tool to take off the inner pannel. Take out faulty power button replace with new one. Take out faulty power button replace with new one.
  • Use plastic opening tool to take off the inner pannel.
  • Take out faulty power button replace with new one.
Jasmin Piena
Membre depuis le 09/04/2018
280 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 35
Total : 35
