Aller au contenu principal
LG Optimus G Pro Battery Replacement
Ce dont vous avez besoin
  1. LG Optimus G Pro Battery Replacement, Remove Back Cover.: étape 1, image 1 de 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Battery Replacement, Remove the Battery.: étape 2, image 1 de 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
10 autres ont terminé cette réparation.
Wesley Pate
Membre depuis le 09/25/14
1 641 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 15-5, Remmell Fall 2014 Membre de l'équipe USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 3,170
