Introduction
The following guide explains how to replace the home button.
Pièces
Aucune pièce nécessaire.
Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone. Remove the battery and SIM card.
  • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
  • Remove the battery and SIM card.
Ajouter un commentaire
Remove the twelve screws using the Phillips 000 screwdriver.
  • Remove the twelve screws using the Phillips 000 screwdriver.
Remove bottom plate where the charger port is located.
  • Remove bottom plate where the charger port is located.
Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover. Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
Flip over to the face of the device.
  • Flip over to the face of the device.
  • Lift off the glass screen (display).
Remove the home screen button. Replace as needed.
  • Remove the home screen button. Replace as needed.
Bruna
Membre depuis le 08/10/2014
519 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 9-1, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 membres
5 tutoriels rédigés
in the step 2, one red ring is in the wrong position.
The ring in the midle at the left side is in the center of the telephone
Tiago - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 1,569
