Aller au contenu principal
LG Optimus L9 P769 Micro-USB Port Replacement
Ce dont vous avez besoin
  1. LG Optimus L9 P769 Micro-USB Port Replacement, Micro-USB Port: étape 1, image 1 de 1
    • Power off the device and gently lift the battery cover off to access the battery
  2. LG Optimus L9 P769 Micro-USB Port Replacement: étape 2, image 1 de 1
    • Lift and remove the battery from the notch in the edge of the battery compartment
  3. LG Optimus L9 P769 Micro-USB Port Replacement: étape 3, image 1 de 2 LG Optimus L9 P769 Micro-USB Port Replacement: étape 3, image 2 de 2
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using a PH000 screwdriver.
  4. LG Optimus L9 P769 Micro-USB Port Replacement: étape 4, image 1 de 2 LG Optimus L9 P769 Micro-USB Port Replacement: étape 4, image 2 de 2
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  5. LG Optimus L9 P769 Micro-USB Port Replacement: étape 5, image 1 de 3 LG Optimus L9 P769 Micro-USB Port Replacement: étape 5, image 2 de 3 LG Optimus L9 P769 Micro-USB Port Replacement: étape 5, image 3 de 3
    • Remove both connections of the antenna by pulling up with tweezers
  6. LG Optimus L9 P769 Micro-USB Port Replacement: étape 6, image 1 de 3 LG Optimus L9 P769 Micro-USB Port Replacement: étape 6, image 2 de 3 LG Optimus L9 P769 Micro-USB Port Replacement: étape 6, image 3 de 3
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  7. LG Optimus L9 P769 Micro-USB Port Replacement: étape 7, image 1 de 1
    • Detach module from motherboard using a prying tool
  8. LG Optimus L9 P769 Micro-USB Port Replacement: étape 8, image 1 de 2 LG Optimus L9 P769 Micro-USB Port Replacement: étape 8, image 2 de 2
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  9. LG Optimus L9 P769 Micro-USB Port Replacement: étape 9, image 1 de 2 LG Optimus L9 P769 Micro-USB Port Replacement: étape 9, image 2 de 2
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  10. LG Optimus L9 P769 Micro-USB Port Replacement: étape 10, image 1 de 1
    • Comparison showing the Micro-USB module against the empty phone casing
Kayden G
Membre depuis le 03/01/17
272 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G1, Harley Spring 2017 Membre de l'équipe IUPUI, Team S2-G1, Harley Spring 2017
IUPUI-HARLEY-S17S2G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 318
