Pièces
This guide will replace the battery for an LG Optimus V. This guide will replace the battery for an LG Optimus V.
  • This guide will replace the battery for an LG Optimus V.
Ajouter un commentaire
Turn the LG Optimus V over so that the back cover is facing upward.
  • Turn the LG Optimus V over so that the back cover is facing upward.
Locate the opening right above the camera.
  • Locate the opening right above the camera.
  • Use your plastic spudger to detach the back cover.
The battery is indicated by the rectangular marker in the photo. Gently remove the battery with your spudger. The battery is indicated by the rectangular marker in the photo. Gently remove the battery with your spudger. The battery is indicated by the rectangular marker in the photo. Gently remove the battery with your spudger.
  • The battery is indicated by the rectangular marker in the photo. Gently remove the battery with your spudger.
This silver casing has 6 screws holding it on. Take your screw driver and unscrew all of them. Now take your prying tool and use it to remove the silver casing. This will reveal more parts of the phone.
  • This silver casing has 6 screws holding it on. Take your screw driver and unscrew all of them.
  • Now take your prying tool and use it to remove the silver casing. This will reveal more parts of the phone.
This big black thing is the antenna. You will need to remove this to get access to the camera area. Use your prying tools to remove each area holding the parts together Use your prying tools to remove each area holding the parts together
  • This big black thing is the antenna. You will need to remove this to get access to the camera area.
  • Use your prying tools to remove each area holding the parts together
Now you have access to the parts and can start replacing and repairing.
  • Now you have access to the parts and can start replacing and repairing.
  • The area circled in red is the camera
Use your prying to first remove the small black and yellow peice that reads Y3114C After that part has been lifted, you can procede to prying off the camera.
  • Use your prying to first remove the small black and yellow peice that reads Y3114C
  • After that part has been lifted, you can procede to prying off the camera.
  • Now just put your new one back on and connect the black and yellow piece
This part circled in red is the antenna
  • This part circled in red is the antenna
Solder off the antenna and solder on the new one. The antenna is now replaced.
  • Solder off the antenna and solder on the new one. The antenna is now replaced.
3 autre(s) ont terminé cette réparation.
Joseph Pasquantonio
Membre depuis le 29/10/2013
679 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Membre de l'équipe UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 20
Total : 1,731
