Introduction
For this removal you will need a PH00 screw driver to remove the necessary screws. It is recommended to have very clean hands or even to wear gloves as you will be interacting with the motherboard of the phone.
First you need to remove the back case of the phone. Place the phone face down. Using the plastic opening tool, insert into the initial gap shown.
  • First you need to remove the back case of the phone.
  • Place the phone face down.
  • Using the plastic opening tool, insert into the initial gap shown.
  • Slowly guide the tool around the case until the case comes off with ease.
Ajouter un commentaire
Place the back case to the side. Use your finger or the opening tool to remove battery. Remove the battery carefully to not damage the phone or the battery.
  • Place the back case to the side.
  • Use your finger or the opening tool to remove battery.
  • Remove the battery carefully to not damage the phone or the battery.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the eleven 4mm Phillips #00 screws. Place screws in safe location. Use Plastic opener tool to remove inner case.
  • Remove the eleven 4mm Phillips #00 screws.
  • Place screws in safe location.
  • Use Plastic opener tool to remove inner case.
  • Gently remove inner case.
Use your finger or the opener to flip the flex cable shown in red box. Use the precision tweezers to remove camera carefully. Use the precision tweezers to remove camera carefully.
  • Use your finger or the opener to flip the flex cable shown in red box.
  • Use the precision tweezers to remove camera carefully.
Devon Barber
Membre depuis le 13/02/2018
474 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S11-G1, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 13
