Introduction
In this guide we will teach you how to properly remove and replace the LG Tribute HD's volume and power buttons
Pièces
Aucune pièce nécessaire.
Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
Ajouter un commentaire
Pull the battery out of the phone. Remove the SD Card by sliding the card out as shown.
  • Pull the battery out of the phone.
  • Remove the SD Card by sliding the card out as shown.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the 12-2mm Phillips head screws. Remove the 12-2mm Phillips head screws.
  • Remove the 12-2mm Phillips head screws.
Using a plastic opening tool, remove the small cover located at the bottom of the phone. Do this by prying the cover up in the available gaps. Using a plastic opening tool, remove the small cover located at the bottom of the phone. Do this by prying the cover up in the available gaps. Using a plastic opening tool, remove the small cover located at the bottom of the phone. Do this by prying the cover up in the available gaps.
  • Using a plastic opening tool, remove the small cover located at the bottom of the phone. Do this by prying the cover up in the available gaps.
Using your fingers, remove the entire back panel of the phone. This reveals the internal electronics. Using your fingers, remove the entire back panel of the phone. This reveals the internal electronics.
  • Using your fingers, remove the entire back panel of the phone. This reveals the internal electronics.
Locate the buttons on the sides of the back panel. Use a plastic opening tool to remove the buttons by pushing them in until they pop through.
  • Locate the buttons on the sides of the back panel.
  • Use a plastic opening tool to remove the buttons by pushing them in until they pop through.
Dhruv Patel
Membre depuis le 14/02/2018
265 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 17
Total : 89
