Introduction
This guide will teach you how to properly repair or replace the front camera in the LG Tribute HD LS676. The front camera may need cleaning if the lens has been damaged by water, dirt or sand. There may also be connectivity issues to the motherbaord which will require disconnecting and reconnecting the ribbon cable from the camera to the motherboard. However, if the front lens is broken or damaged causing the camera not to turn on, then is has to be replaced.
Pièces
Aucune pièce nécessaire.
Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
Ajouter un commentaire
Pull the battery out of the phone. Remove the SD Card by sliding the card out as shown.
  • Pull the battery out of the phone.
  • Remove the SD Card by sliding the card out as shown.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the twelve 2mm JIS #00 screws from the mid-frame. Remove the twelve 2mm JIS #00 screws from the mid-frame.
  • Remove the twelve 2mm JIS #00 screws from the mid-frame.
Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame.
  • Using a plastic opening tool, remove the antenna extender from the mid-frame.
Using your fingers, remove the mid-frame. Using your fingers, remove the mid-frame.
  • Using your fingers, remove the mid-frame.
Use a plastic opening tool to disconnect the front camera from the motherboard and pull out to remove. Use a plastic opening tool to disconnect the front camera from the motherboard and pull out to remove.
  • Use a plastic opening tool to disconnect the front camera from the motherboard and pull out to remove.
Aalia Mohammed
Membre depuis le 14/02/2018
424 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 8
Total : 53
