Introduction
This guide will teach you how to properly replace the headset jack port in the LG Tribute HD LS676.
Pièces
Aucune pièce nécessaire.
Locate the tab on the back cover and insert a plastic opening tool or fingernail to lift up. Proceed to slide tool along the sides to fully dislodge cover. Locate the tab on the back cover and insert a plastic opening tool or fingernail to lift up. Proceed to slide tool along the sides to fully dislodge cover.
  • Locate the tab on the back cover and insert a plastic opening tool or fingernail to lift up. Proceed to slide tool along the sides to fully dislodge cover.
Ajouter un commentaire
Using a plastic opening tool or fingers, remove the battery from the phone by lifting the bottom edge of the battery. Remove the SD Card by sliding the card out as shown.
  • Using a plastic opening tool or fingers, remove the battery from the phone by lifting the bottom edge of the battery.
  • Remove the SD Card by sliding the card out as shown.
Remove the 12 - 2 mm Phillips head screws. Remove the 12 - 2 mm Phillips head screws.
  • Remove the 12 - 2 mm Phillips head screws.
Using a plastic opening tool, remove the small cover located at the bottom of the phone. Do this by prying the cover up in the available gaps. Using a plastic opening tool, remove the small cover located at the bottom of the phone. Do this by prying the cover up in the available gaps. Using a plastic opening tool, remove the small cover located at the bottom of the phone. Do this by prying the cover up in the available gaps.
  • Using a plastic opening tool, remove the small cover located at the bottom of the phone. Do this by prying the cover up in the available gaps.
Using your fingers, remove the entire back panel of the phone revealing the internal electronics. Using your fingers, remove the entire back panel of the phone revealing the internal electronics.
  • Using your fingers, remove the entire back panel of the phone revealing the internal electronics.
Use plastic opening tool to pry up the flex cable from the back panel. Flip over and push the back side of the Headset Jack Port to dislodge it. If it did not completely dislodge, use your fingers to fully remove the component.
  • Use plastic opening tool to pry up the flex cable from the back panel.
  • Flip over and push the back side of the Headset Jack Port to dislodge it.
  • If it did not completely dislodge, use your fingers to fully remove the component.
Jerry Koenig
Membre depuis le 14/02/2018
461 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 53
