Push the light gray rectangle in the top-center up. While pushing up grab the sides of the battery and pull out. While pushing up grab the sides of the battery and pull out.
  • Push the light gray rectangle in the top-center up.
  • While pushing up grab the sides of the battery and pull out.
Ajouter un commentaire
Unscrew the antenna by grasping the base and twisting counterclockwise.
  • Unscrew the antenna by grasping the base and twisting counterclockwise.
    • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
  • The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
Using a Torx screwdriver with a T6-sized bit, unscrew the four screws on the back of the phone. The bit size is engraved on the base of the bit head.
  • Using a Torx screwdriver with a T6-sized bit, unscrew the four screws on the back of the phone.
    • The bit size is engraved on the base of the bit head.
With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone. Gently pull the two pieces apart to separate. Apply enough force to separate the pieces without cracking the back cover.
  • With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone.
  • Gently pull the two pieces apart to separate.
    • Apply enough force to separate the pieces without cracking the back cover.
Lift the computer chip to gain access to the keypad and side buttons beneath. CAUTION: The computer chip is attached with a thin ribbon wire at upper right corner of case. DO NOT BREAK THE RIBBON WIRE.
  • Lift the computer chip to gain access to the keypad and side buttons beneath.
    • CAUTION: The computer chip is attached with a thin ribbon wire at upper right corner of case. DO NOT BREAK THE RIBBON WIRE.
Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace. Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace. Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace.
  • Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace.
Nico Chiarito
Membre depuis le 21/01/2010
22 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 8-47, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,600
